1000 de cat
Re: 1000 de cat
Postby boilermaker » Tue Dec 15, 2009 4:55 am
Werner
Forgot to mention that if you are looking for tubing then it should be API Schedule 10 wall thickness in AWS 304 or nearest 18/8 Stainless Steel. For this application it does not need to be seamless tubing.
George
boilermaker
Re: 1000 de cat
Postby TheQK1 » Thu Dec 17, 2009 1:07 am
Thanks a lot.....
You've opened the can (lol); I will have to do a lot more homework before taking the bike in. Will have to find out if the guys have the correct materials and the alternator and ECU thing is scary stuff if not done correctly?
Your advice is great stuff.
Regards
Werner
TheQK1
Re: 1000 de cat
Postby boilermaker » Thu Dec 17, 2009 1:28 am
Werner
Your local custom car/bike exhaust manufacturer should be able to carry out the work as long as you give him the info that I have specified. As a bonus they can probably carry out the work "off the bike" thereby removing the requirement for electrical/electronic isolation.
George
boilermaker
Re: 1000 de cat
Postby TheQK1 » Mon Dec 21, 2009 1:18 am
Yip, you are right
Before doing the deed is there no way to clean the Cat filtes?? Maybe I can do that first and depending on the success I will then consider the alternatives.
:D
Regards
Werner
TheQK1
Re: 1000 de cat
Postby boilermaker » Mon Dec 21, 2009 1:13 pm
Werner
I am having trouble with this dirty cat bit. If your catalyst has been running at the right temperature then it is virtually self-cleaning (if a little dangerous on a bike). The only way to foul a cat would be to expose it to leaded, contaminated, or heavily oiled fuel and in all three cases this renders the cat useless in the permanent sense! My advice to you (for what it is worth) is to junk the bloody things ASAP.
George
boilermaker
Re: 1000 de cat
Postby iceman » Sat Jan 16, 2010 4:16 pm
If anyone wants to do this but can't find a sensor,well here it is. http://cgi.ebay.de/Lambdasonde-MZ-1000- ... 439a928638
A complete bike<SF> on Ebay Germany in parts...Frame ,shock,swing-arm,wiring harness..etc. Even my tank but 290 Euro
John Lennon
iceman
Re: 1000 de cat
Postby TheQK1 » Mon Feb 22, 2010 1:50 am
Thanks for all the help guys, I will do the de CAt thing as soon as I've got the funds. I first need to save up for a few otherr thing on the bike, that I will purchese from Grahams.
Regards
Werner
TheQK1
Previous
Return to 1000S
Users browsing this forum: No registered users and 113 guests
