gearchange
gearchange
Postby boilermaker » Mon Aug 17, 2009 3:21 pm
To all
Anyone had any problems with lever travel? I am having minor problems selecting first on down change, checked all external possibilities would rather not contemplate opening box if someone has a suggestion/info.
boilermaker
Re: gearchange
Postby iceman » Mon Aug 17, 2009 4:55 pm
I found this online...
This is almost always caused by grime building up on the shafts, causing some binding.... the spring can'[t return to it's correct position, so you can't get the second shift done.
Take either some WD-40, or some Lithium spray on grease, and lubricate every single pivoting point in the shifter linkage. The lever pivot, the ball joints at either end of the shifter rod, and especially the input shaft to the transmission.
Should clear right up.
John Lennon
iceman
Re: gearchange
Postby boilermaker » Tue Aug 18, 2009 5:04 am
Iceman
Thanks John will give it a try
George
boilermaker
Re: gearchange
Postby boilermaker » Fri Oct 30, 2009 2:25 pm
Well lads
Looks as if I am going to have to pull the gear selector machanism to replace the return spring. I think that I will replace all three springs whilst I am about it. Will let you know how I get on. This means the Yamaha will have to come out of hibernation!
boilermaker
Re: gearchange
Postby Jamie » Sun Nov 01, 2009 3:29 pm
Good luck.
Jamie
In Devon
Jamie
Re: gearchange
Postby Stephenonz » Mon Nov 02, 2009 4:14 am
I had this problem with my ST, and all I did was to loosen the screw a touch on the gearchange ball joint and use a lock nut to secure it. I had no problems since.
Stephenonz
Re: gearchange
Postby johnny2tents » Mon Nov 02, 2009 8:33 am
Hi Boilermaker,
I've done exactly the same as the previous post on the ST. When I had the 'slide off' and initially fitted the S lever, I did it up too tight and could only change gear up through the box with difficulty, couldn't change down at all!
Slackening it off a tad and adding a lock nut solved my problem. When I straightened the original ST lever and re-fitted it, I put a lock nut on this as well. Works perfectly. I was getiing horrible ideas about diving into the gear selectors too.
Hope yours is as simple as this to fix. Regards J2T
johnny2tents
Re: gearchange
Postby johnny2tents » Mon Nov 02, 2009 8:41 am
Welcome aboard Stephenonz and your ST, are you in Somerset, or north of the Pentland Firth, or somewhere else entirely? Cheers J2T
johnny2tents
Re: gearchange
Postby boilermaker » Mon Nov 02, 2009 1:53 pm
Thanks for the tips lads will keepm you posted.
boilermaker
Re: gearchange
Postby Stephenonz » Wed Nov 11, 2009 4:50 am
I'm in a place a bit further away - New Zealand in fact. I'm one of the few MZ 1000 owners here.
Stephenonz
Re: gearchange
Postby johnny2tents » Thu Nov 12, 2009 7:45 am
Well you are still nearer Somerset then! The nz suffix was a bit of a give away! Enjoy your summer. Cheers J2T
johnny2tents
Re: gearchange
Postby boilermaker » Thu Nov 12, 2009 5:58 pm
Stephanonz
How many 1000s made it to NZ then because as far as I know next to none made it to OZ.
boilermaker
Re: gearchange
Postby Stephenonz » Fri Nov 13, 2009 4:38 am
I'd be guessing but it can't be more than 10 in New Zealand; mainly 1000S's and 1000SF's. The Brook Brothers in New Plymouth had the import agency for them, but they never really caught on; even though they got good reviews in the local motorcycle press.
There's a low km 1000S currently for sale in Hamilton for a good price: http://www.hamiltonmotorcycles.co.nz/us ... nsport.htm. If I had a few spare $ I'd buy it and put it away.
Stephenonz
Re: gearchange
Postby TheQK1 » Mon Dec 14, 2009 6:43 am
boilermaker wrote:Well lads
Hi
Had the same prob. with my 1000S, one of the selector springs was broken; this caused me not being able to down gear. I had no service manual at that stage and it took me a long time to identify the prom. as the spring was broken in such a way that it was not easy noticeable.
The gear changes are still not smooth, maybe I’ll have to change all the springs, I will have to order them though and shipped to SA.
Regards
Werner
TheQK1
Return to 1000S
