Skorpion Tour Air Filter--Grahams, K&N, Others?
Postby J-Ball » Fri Oct 30, 2009 9:15 am
Hi All,
Searching for a replacement air filter for a Skorp Tour (2000), My search results here have led me to the KN Filter KA-5087. Any others to consider?
On a side note, I've read here that removing the fine screen in the petcock helps the carb see more gas, I have a secondary fuel filter, is it ok to loose the screen, will it make any difference? Ok to drill out the petcock? Bit size?
Thanks and ride on.........
J-Ball
J-Ball
Re: Skorpion Tour Air Filter--Grahams, K&N, Others?
Postby DAVID THOMPSON » Fri Oct 30, 2009 10:01 am
rt125 and 660 both use same air filter
i removed the old filter paper from the plastic frame
and replaced it with uni sheet filter foam
so now mine are rebuilt and washable
Postby J-Ball » Sun Nov 01, 2009 9:02 am
Smart Dave I like it. Sounds a lot less expensive than the K&N route. It's about the same size as the Uni I just got for my XT, I'll have to do some chin scratching and see if I can make one of those work. Where did you get your Uni sheet from, a specific application?
Anyone happen to know if you can use K&N oil on a virgin Uni filter or is the oil different.
J-Ball
J-Ball
Postby DAVID THOMPSON » Sun Nov 01, 2009 9:45 am
foam from local MC shop
i will see if i can find the uni part number
and i do not oil mine
Postby J-Ball » Sun Nov 01, 2009 12:17 pm
Thanks Dave, part number would be great. The XT Uni has two sides, like a pouch... yellow on one side and red on the other i think. Is yours a double side?
No oil eh? The MZ and the XT see lots of dirt so I'm thinking oil is mandatory. Comments?
J-Ball
J-Ball
Postby bikeseamus » Fri Dec 11, 2009 7:34 pm
Oil is MANDATORY for dusty conditions. End of subject
bikeseamus
Users browsing this forum: No registered users and 44 guests
