ignition coil again
ignition coil again
Postby hutchy » Sun Jan 25, 2009 5:25 am
Hello all, I'm still looking for a high power coil to use with the standard baggy ignition.
I've tried dyna coils by dynojet uk but they can't supply one within the standard range (3.4 -4.6 ohms), the one Bill uses is 2.7 ohms but this is used with a replacement ignition( bit too costly for me just for running around on)
I was wondering what difference it would make if i fitted a coil that was outside this range say :3 or 5 ohms, I have very little experience of this side of electrical engineering so I would appreciate any help from any of you clever boffins.
Cheers all........Hutchy
hutchy
Re: ignition coil again
Postby Bill Jurgenson » Sun Jan 25, 2009 9:53 am
to be sure, I used that coil with that Silenthektik ignition on my all-outracer, but I also use that same coil with the standard ignition in my blue street Skorpion and have been doing so for years.
can easily be seen here: the blue bike was always a street bike with starter and standard ignition.
That bike, now sold and painted green, is used only on the track, albeit with the czech box I have often referred to. Of course it uses the Silenthektik coil.
I also sent one to my friend Chris Hunsicker in Philidelphia for his track Skorpion which also uses the the standard battery ignition and starter.
Of course I use it in my present street Skorpion
here, 2008, my green street Skorpion with the same coil and obviously original DENSO box, tho mounted in a different place.
In the meantime I have changed over to the Ignitech box which I also use in the SZR. Here, I am still using the Denso coil because there is so lttle room behind the fairing and the mount so close to the deltabox frame to accomodte the MotoCoil. On the Skorpion, one needs only to bend the welded tabs on the frame inward to make room for the much larger coil. This can sorta be seen in the pics. One also need a different lead to the plug for the SilentHektik coil, one with a standard car-type plug at the coil. I use a BERU lead myself; you can see the blue lead.
Postby Old Dog » Sun Jan 25, 2009 2:07 pm
Hi Bill,
sort of off topic but can that airfilter be fitted to the OE carbs?
TIA
All the best
Old Dog
Old Dog
Postby Bill Jurgenson » Mon Jan 26, 2009 6:02 am
I haven't tried; it might. But you will need to make a sleeve to fit over the left side of the OEM carb.
Postby hutchy » Sat Jan 31, 2009 4:18 pm
Thanks for your help Bill.........Hutchy
hutchy
