TS250 Oil Change Procedure.
Postby paulo » Sun Sep 14, 2008 1:39 pm
Think maybe it's time to change the gearbox oil...
...in trying to locate the drain plug I consulted my old Haynes manual but I can't quite find a plug "underneath the right-hand side of the gearbox in an inclined position".
I'd be grateful for any help.
Also what oil would you recommend?
How about an 'engine flush' type product prior to the change - worth it?
Any assistance gratefully received.
paulo
Re: TS250 Oil Change Procedure.
Postby DAVID THOMPSON » Sun Sep 14, 2008 10:57 pm
what year
a lot of the 2 smokers pre 1975 used a 30 or 40 weight non detergent oil in the box
some one in the uk speak up
the 2 smokers are so rare in my area other than a weed eater the guy next door has a lawn boy
and a boat motor
Postby paulo » Mon Sep 15, 2008 1:56 pm
1978...
paulo
Postby manumensa » Mon Sep 15, 2008 4:58 pm
Hello!
Yes Paulo, up the motorcycle in a elevator or you stoop and see two plug but only one (the big) in an inclined position (the drain plug) like said Haynes book.
The engine must be heat -Careful with the skin burn-
Oil : 750 cc. SAE 80 EP
Manual MZ said (like said Thompson) alternative oil SAE 30W40. The problem this oil generally are formulated for car engine (dry clutch), the clutch can slip in the MZ and you must be change (no enougth change for correct oil) contamitated friction disc.
Manual MZ said also chage oil every 20.000 Kms!! :shock: . Oil isn´t expensive, you can change (aprox.) every 5.000 km for long life and clean engine when you open to repair; oil for engine is like blood for us, (sorry for the obvious).
Saludos, Manuel
manumensa
Postby paulo » Tue Sep 16, 2008 12:30 pm
I just can't see anything in an inclined position.
Any chance of a pic?
paulo
Postby manumensa » Sun Sep 21, 2008 5:17 pm
Hello Paolo!
The drain plug are situated on underside of the crankcase (a bit on rear position) near footrest bar. Is a inclined (I think 17 mm) plug with magnet. :wink:
Saludos, Manuel.
manumensa
Postby colm54 » Thu Nov 20, 2008 12:07 am
Hi Paulo, When you are changing the oil on the TS 250/1, you drain the oil from two different places. Most of the oil is in the clutch casing and you drain that by removing the bottom screw of the CLUTCH CASING screws. The rest of the oil you drain from the 22mm nut under the engine. Do NOT remove the 17mm nut as this holds in the ball bearing and spring for the neutral detent position.
The correct oil for this engine is 80W Hypoid gear oil. There are others I would recommend ie Silkolene 75W Light Gear OIl, Castrol Syntec 75W90. The capacity of the gearbox is 900cc. If you put in too much you can have problems with the oil leaking from different places.
colm54
Postby manumensa » Sat Nov 22, 2008 7:28 am
Hello!
Paulo wrote can´t find "a plug underneath the right-hand side of the gearbox in an inclined position" and after "1978". It´s a TS250/1.
Sorry Paulo, I was stubborn in the post title "TS 250..."
After ask "Any chance of a pic?" -1 picture better than 1000 words- I could do it but
I didn´t do it.
Really I was lazy ...and vague. Sorry again Paulo.
Two months after -later better than never- pictures TS250 and TS250/1:
http://www.mz-b.de/miraculis/aw/mz/text/ts250r/16.jpg
http://www.mz-b.de/miraculis/aw/mz/text/ts251r/14.gif
Thank you, colm54 for to correct me.
Is very difficult found a mechanic MZ with long experience and he use his time for reply in forums. I hope read your posts in the future. Thank you again colm 54.
Best regards,
Manuel Muñoz Consuegra
manumensa
