soggy front end
soggy front end
Postby hutchy » Fri Aug 08, 2008 2:42 pm
Hi everyone , just looking for some help. I want to change the fork oil but there doesn't seem to be a drain on the fork legs so do I have to take off the legs and drain them upside down through the top caps? also I want to stiffen up the front end a wee bit so would using 10 grade fork oil help? cheers........Hutchy
hutchy
Re: soggy front end
Postby Bill Jurgenson » Sat Aug 09, 2008 1:02 am
Skorpion? Baggy?
you have to take off the leg and empty it out at thru the top.
Heavier oil make it more sluggish , not stiffer.
Less air column, i.e. more oil makes it stiffer.
Re: soggy front end
Postby kendo » Sat Aug 09, 2008 8:11 am
I changed the fork oil on my 02 Baggy to 15 weight and fitted longer preload spacers to the forks and it made a huge improvement to the way the front end feels.
Hope this helps,
Kenny.
kendo
Re: soggy front end
Postby AtomicSpew » Fri Aug 15, 2008 7:01 pm
The guys at Sonic Springs can set you up with a pair of stiffer springs...Just ordered a pair (yet to install), but I swapped out my springs with Sonics on my VStrom and holy moly what a difference! I hold faith that the same will be true of the Baggy once I get around to installing them...
_______________________________________
03 Baghira
03 CRF150F (w/BBR 175 hop-up)
Stop, drop and roll doesn't work in hell...
AtomicSpew
Re: soggy front end
Postby hutchy » Sat Aug 16, 2008 2:52 pm
thanks for the help.........hutchy
hutchy
Users browsing this forum: Bing [Bot] and 49 guests
