So how can I get the bolt out that the nut spins on? How can I stop the nut from spinning?
mechanicalmarc wrote:I just bought a Skorpion with the same problem. Did you come up with a solution? Or are you still removing the tank with the 4 bolts on the sub-frame? BAD DESIGN!
