choke mech on Baghira
Postby dozzyd » Wed Jan 16, 2008 11:33 am
It now seems that i may have a siezed choke valve as operating the lever just results in creating slack and pulling at the sleave rather than the cable,Phlars, i believe you mentioned this. I have removed the brass nut and put some releasing stuff into the mech but i fear thet may not be enough. Do i need to remove the carb to get at this valve to free it off,and if so, any hints on removal would be most welcome...
dozzyd
Re: choke mech on Baghira
Postby Stuart109 » Thu Jan 24, 2008 9:21 am
Hi
The choke mechanism is attached to the end of the cable and should pull out from the side of the carb once you have unscrewed the brass nut. There is no need to remove the carb to get at the thing.
Stuart
Stuart109
Postby dozzyd » Tue Jan 29, 2008 6:40 am
Thanks for that Stuart,just what i needed to know,i have removed the brass nut previously but have been reluctant to pull too hard on the cable not knowing quite what's in there or how it works,so i'll take another look and maybe pull a little harder this time! Regards. Ian
dozzyd
Postby DAVID THOMPSON » Tue Jan 29, 2008 10:10 am
a little spray oil like wd40 or pb blaster to help as the brass on brass parts
in there get gummed up with the left over bad gas
Users browsing this forum: Bing [Bot] and 204 guests
