keithcross wrote:Hey Brian, for grip try Avon Pro extreme wets. They are brill and are a bit wider tham other tyres, not sure about wear rate yet on the baggy. I will keep you informed, as I hope its better than teh 750 miles a friend gets from his tuned WR450 Yam. Mind you he does do track days in that milage as well. I hope to better 1000 miles. Also heard that Maxxis Goldspeeds in the silver compound affoer equivelent grip with better milage.
I also have a set of Avon Distanza's to try out later and will let everone know what they are like.
So far I have tried the following tyres
Perelli MT60's. Standard tyres that I quite liked but teh second rear only lasted for 1900 miles
Koncorde remoulds real cheap (£45 per pair for cosmetic seconds). Good grip with the rear lasting 2500 miles, ok in the wet to.
keithcross wrote:Common Gedge, where did ou get the new rear light from and is there any chance you can show how you have mounted it and the rear indicators.
gedge wrote:The LED is from MOTRAX, cost £24 ( medium size) . Very bright running light and super bright brakelight... Looks good in the dark ( bit like me ). The whole lot is mounted on a UFO universal rear plate holder which has a recess to mount the indicators ( that was about 20 quid as well).
I agree re the horrible , huge Number plate. Its a real bone of contention inthe UK with most bikers risking a fine for having a small one ( more inuendo pleeeeaasse). sadly as an upholder of the dreaded law , I have to stick with the nasty big bugger...
Get your questions in quick as I am just off to gran canaria , and anything after 2200 GMT will have to wait a fortnight
See you all soon.
Users browsing this forum: No registered users and 229 guests
