LED replacements for Tail light bulb
Postby 125SMash » Sun Oct 28, 2007 10:14 pm
i heard some people describe benefits of replacing stock bulbs with LEDs, for the lower power consumption and heat generation. does anyone here have experience with this to suggest the simplest part # for replacement, and opinion over all?
thanks
2002 MZ 125SM
125SMash
Re: LED replacements for Tail light bulb
Postby Drew » Mon Oct 29, 2007 1:30 am
LEDTronics is the way to go. I've used them in my Daytona and am using one in my 625 SMC. They're a direct drop-in replacement. The radial 6-LEDs fill the reflective cavern very nicely (LEDs are very directional light, so the LEDtronics design helps out a lot).
Try to avoid white LEDs, as they don't produce the right light (blue tint to them), and your taillight will be purpleish, which is a great way to draw attention from cops. With the MZ 125s the rear lens has the clear space for lighting the plate, and LEDtronics have created a bulb to match.
I love them. Long life, low maintenance, lower power draw from the alternator, more resilient to vibes, and fast turn-on time.
I don't know if the MZ uses 1157 bulbs, however. One of my things i need to do is to check that out.
Relax. You'll live longer.
Drew
Postby 125SMash » Tue Oct 30, 2007 9:35 pm
Thanks Drew.
i did some digging and found that rt125 uses type 12-21/5W-P25-2 tail/break light (hopefully its the same for SM)
and i found the 1157 one you mentioned here:
http://www.ledtronics.com/ds/aut1157m/
found a specs comparison here:
http://genet.gelighting.com/LightProduc ... 300v-1.pdf
looks like it is a compatible replacement!
i'll update once i get it.
2002 MZ 125SM
125SMash
Postby Drew » Sat Nov 03, 2007 1:09 pm
No prob.
I believe they come in packs of 2, so you may want to go halvsies with someone :D
Cheers.
Drew
Drew
Postby OSPRNG » Fri Nov 27, 2009 11:31 pm
hey guys, just wanted to add my experience. 80$ was too much for a tail light in my opinion, so i held out.
today i was at a motorcycle mall in Belleville, NJ and saw a led tail light 1157 for 10$ so i grabbed it.
JamStrait LED RADIAL 1157 HRC/HWR
http://www.jamstrait.com
installation was a breeze, and the LED has both the straight LED red stop light and the 90 degree white light to eluminate the license plate.
strangely, in standard mode the red lights kick in, and when you hit the breaks the white lights add in -
basically the reverse of what youd expect.
but it works out because as you ride your license plate is dim but visible, and the riding light is more visible than normal (always a good thing with cagers imho) and when you hit the brakes it still gets brighter to make the difference.
either way, $10 beats paying 80$ plus postage! :D
OSPRNG
Postby RiverDrive » Sat Nov 28, 2009 8:52 am
I have tried these, they are not nearly as bright as incandescent. However I do carry one in my tool kit. I've had to use it in a pinch on a dark road.
01 Sport Cup Gone Sport
RiverDrive
Postby borisattva » Wed Dec 02, 2009 8:17 pm
OSPRNG,
I've used these in the past:
http://www.superbrightleds.com/cgi-bin/ ... roduct=CAR
(look for "1157-R19W6 Motorcycle Tail LED bulb" 1/4 down the page.)
this one is a drop-in replacement and didnt require any voltage modification on a SM.
it also didnt have the reverse lights problem you described.
$12
borisattva
Site Admin
Postby pinhead1990 » Fri Oct 26, 2012 9:54 am
I replaced my rear brake light for LED on my 125 sm
http://www.mzriders.com/viewtopic.php?f=4&t=5000
never had a problem since, its bright enough and not had to change a bulb/led anything as of yet :lol:
pinhead1990
Return to 125 cc
Users browsing this forum: No registered users and 204 guests
