fairing stays
fairing stays
Postby basser23 » Sun Jul 15, 2007 10:28 am
In need of a left hand upper fairing stay for a 96 Skoprion sport.
Age and vibration broke the tab mount on the frame side.Good clean
break though.....
The one needed mounts the mirror/at the top,the fairing at the rear and
frame to the right rear..
Chip
basser23
Postby Chris Hunsicker » Thu Sep 06, 2007 3:28 pm
Chip, Is this for a track only bike? If so, consider this as an alternative:
http://www.philadelphiariders.com/gallery/album43/P8010092?full=1
Caution, large image. Full download not necessary.
I made the rear brackets out of 3/4" flat aluminum. Other tools needed are a hammer, a vise, and a drill. :-D
-Chris
PS You doing any more track days this year? I hope to do Beaver in early October with STT, and maybe a Summit Main...
Chris Hunsicker
Postby Bill Jurgenson » Fri Sep 07, 2007 1:10 am
I, too, have only the lower bracket, similar to what Chris has but from steel tubing, actually just the original part trimmed to a minimum. Never had the vertical part up the mirror, only the cage tube from the front to support the mirror even when the bike as street going.
Why don't you just weld it back together, it is all of mild steel in the OEM version?
If you are using the original mirrors, you probably need the support. I have mirrors from the Cagiva Mito.
Having decided not to race any more, the racer will look a bit like that again, with full fairing and a different better exhaust taken from my blue bike which as been retired for parts. I want to register it again for the road.
the street-legal "racer" originally looked like this:
RWE 1.jpg (63.01 KiB) Viewed 2719 times
you can just see the mountings here.
fairing stay
Postby basser23 » Thu Sep 13, 2007 3:27 pm
Bill,
I just had the original welded up. Mark at Slipstream (aka Wonky) was
going to ship me one,but havent seen it as yet...no big deal...
Chris, wont be doing any track days this year....may go to Summit
soon though...
I have been in UK for the past 2 weeks..just got back...too much going
on at the house to ride at this point...drat!!!! and the weather is perfect..
basser23
Return to Wanted
