Bill Jurgenson wrote:Do not make the mistake to replace the rear unit with another Bilstein like the original. There are several alternatives, all much better and some of them cheaper as well.
The most obvious is of course to use a high-end made to order strut from Wilbers or WP. Altho this is by far the most expensive, it is also the best bet in the long run because such struts are completely rebuildable and work best. The WP OEM strut for the Replica can be had directly.
The red Sport has a Wilbers strut at the rear, Type 640, which was originally in the blue Tour. I bought it back in the 90ies when the Bilstein broke. Rebound and length adjustments.
The Tour, my "test bed," presently has an older fully adjustable Wilbers for an FZR with separate pressure chamber gotten used at eBay for maybe 150€. This fits 1:1 with no modifications and is slightly longer, raising the tail for better handling in the process. It is also adjustable in length.
Before I got that one, I modified the Sachs strut from the Aprilia RS250. Here is one:
http://cgi.ebay.de/Aprilia-RS-250-Sachs-Federbein-hinten_W0QQitemZ250105283323QQihZ015QQcategoryZ78421QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This works very well with a different spring. THe WP spring for the Skorpion Replica can be had from WP and fits this strut perfectly. This is what I used. This strut has been used by several Skorpion riders. The modifications are not difficult, but it is not plug and play; some machining is necessary, both at the top and bottom. Once fitted, it is very good.
Then some OEM Yamaha struts fit directly. Obviously, the strut from the FZR:http://cgi.ebay.de/Yamaha-FZR-1000-Federbein-mit-Umlenkung_W0QQitemZ150112837362QQihZ005QQcategoryZ49809QQrdZ1QQcmdZViewItem
Then the struts from the FZR600 fit as well, but the spring, here, is too weak.
http://cgi.ebay.de/FZR-600-Federbein-NEU-600-R-4JH-3HE_W0QQitemZ330111159972QQihZ014QQcategoryZ49809QQrdZ1QQcmdZViewItem
http://cgi.ebay.de/Federbein-FZR-600-R-4JH_W0QQitemZ140108726711QQihZ004QQcategoryZ49809QQrdZ1QQcmdZViewItem
These things are pretty good, better than the Bilstein at least, adjustable and a dime a dozen. Get any rauchy strut from the 1000er for a handshake and use that spring instead. A friend of mine has experimented a lot with various Yamaha struts. He is not on this forum, so ask for his email offlist.
My racer has a tailor-made Wilbers 641: out of the box-into the bike-perfect!
Just in case, I have the complete linkage in good condition here. And I also have that Sachs strut, modified, which can be bought from me or borrowed as a model for modifying another Sachs strut. At the moment, it is out of house for just that reason.
Users browsing this forum: Bing [Bot] and 16 guests
