DEmark wrote:continued: Do you see any fault in my logic there? The throttle response is VASTLY improved with the accellerator pump carbs, this has GOT to load everything in the motor and transmission more.
HENRI! how many miles you got on your bike now??
OLDMTNCARVER wrote:Wonky,
Hey every time I ride or even look at the BP I know that I'm Waaaaaaaay past sick!!!![]()
Hey get back to work on yours! Hope you cold's way gone, don't hurt yourself, Buddy!
OMC
cat wrote:I must check the Baghira specifications/alternative parts doc - what it specifies as the alternative CDI. If it's the 3VD one, it should come out, it's "unverified information". .........
...Yes, it says
Yamaha TDM 850 (3VD, not 4TX.)
(rev limiter set to 8400,
ignition advance earlier at 38° to 42°)
So, you say the rev limiter - 8400 rpm - doesn't actually work? That it results in there being no rev limiter?
Users browsing this forum: No registered users and 35 guests
