Baghira Rear shock adjust / Air Box
Postby -8- » Thu Jul 01, 2004 3:17 pm
Is it possible to adjust the spring ht on the rear shock without removing the airbox? If not, what's the easiest way to remove the airbox?
Postby phlat65 » Thu Jul 01, 2004 8:19 pm
yes, use a long brass drift and hammer to loosen/tighten the jam ring, support bike on jack and turn spring by hand, should move collar as well, or use drift to turn collar.
Postby Brian » Fri Jul 02, 2004 10:07 am
I pulled my exhaust pipe and mid pipe to use the wrench on mine.......
"Brian" 2003 MZ Baghira
Brian
Will that lower the bike a tad???
Postby sbaschn » Sat Jul 03, 2004 9:35 pm
I just read your post. Will that esentially lower the bike a little???
sbaschn
Postby phlat65 » Mon Jul 05, 2004 4:44 pm
kinda, but not in a good way. if you want to lower the rear, change the "dog bones". you can get them from MZ, or make them your self.
Postby -8- » Thu Jul 08, 2004 5:26 am
Tore the jamp nut up some but got it down about 1/2". Just needed to drop that much so I can get at least 5 toes on the ground.
Users browsing this forum: Google [Bot] and 216 guests
