MZ ETZ251 rear wheel/hub bearing sizes
Postby alexxx » Tue Sep 05, 2017 7:49 am
Hi Folks,
Can anyone tell me the bearing part numbers for an MZ ETZ251 rear wheel/hub?
I was kindly given an e copy of the earlier ETZ manual which has the sizes in it, just want to check if all models had the same rear wheel/hub bearings.
The bearings I removed from the stub axles are both the same but it looks like one should have a smaller inner diameter to match the slightly reduced inner diameter of the stub axle, one certainly is a loose fit so I think a previous owner bought two the same by mistake.
I have no numbers on any of the bearings, the wheel bearings are shielded both sides but again no id.
Regards,
alexxx
Re: MZ ETZ251 rear wheel/hub bearing sizes
Postby Andy_C » Tue Sep 05, 2017 2:35 pm
Try lookig at this thread : viewtopic.php?f=5&t=4502
Andy_C
Postby alexxx » Wed Sep 06, 2017 6:02 am
Thanks Andy,
I had seen that but was unsure if the spoke wheels had the same bearing sizes as the cast wheels.
Cheers
alexxx
Postby Guesi » Wed Sep 06, 2017 2:40 pm
All 2 stroke MZ wheels have 6302 bearings..
Guesi Motorradteile
MZ spare parts
