by Ianmack » Fri Aug 21, 2015 5:46 am
My exhaust ring nut is firmly seized in the cylinder of my TS250. Any good tips for getting it undone please, preferably without damage?
Ianmack
by vicar » Fri Aug 21, 2015 12:47 pm
]HEAT AND MORE HEAT AND THEN A BIT MORE HEAT
vicar
by dunekahn » Sat Aug 22, 2015 8:45 am
I concur. If you have a stuck nut or bolt, heat it up with a propane torch, then try breaking it loose. Heat works wonders on seized fasteners.
D.
2002 MZ Baghira SM (yellow)
1964 Harley Davidson pan/shovel (basket case)
1970 VW Bug (General Vee)
dunekahn
by Ianmack » Thu Aug 27, 2015 4:34 am
Thanks, it responded to heat. Also violence and bad language.
Ianmack
by Blurredman » Thu Aug 27, 2015 5:28 am
Try after a nice ride in hot weather first.
If you cannot do so or it is still seized then like the others have said, use a heat gun, but be careful!
Do you not have the C spanner? I bought an old used one from e-bay especially for this (and to have the tyre iron). It is obviously the best tool for the job, you can get C spanners for the suspension units on a lot of bikes, you could also try them if they fit properly. But alas, Heat and patience and possibly a little metal shock to crack it off.
by MichaelTorre » Wed Sep 16, 2015 9:22 pm
Red heat.
Be gentle.
Head cannot take that kind of heat.
( be quick about it, it travels fast)
Hammering can bind threads if you knock a bunch of rust loose in the joint.
Solution......rock to and fro. (Tighten a wee bit, and loosen ).
Patientence
M-
MichaelTorre
