TS125: smoking voltage regulator
Hello Everyone,
I'm finally back on with trying to sort the TS after a long lay-off. She now runs, but I did notice smoke coming off the insulation on one of the regulator wires (an original mechanical unit). I've since tried the electrics with the engine not running, and nothing untoward happens, so am assuming it's connected to the engine running.
None of the electrics have been chopped/messed about with, though various lights currently don't work. The connections within the regulator are age-corroded - don't know if that's anything to do with it.
At the moment I'm trying to get an idea of what to look for. I'm assuming it was smoking due to too much current going through the wire, but that's about the limit of my electrical knowledge.
Thanks in advance,
Rick
Thanks in advance,
Rick
