Surging ETZ 301
Surging ETZ 301
Postby Andy_C » Sat Sep 06, 2014 3:19 am
Any tips on reducing the amount of "surguing" that I experience on my ETZ ?
Bringing the tickover down as low as it will go and adjusting the air screw to something around half a turn out seems to minimise it.
Any suggestions ?
Andy_C
Re: Surging ETZ 301
Postby DAVID THOMPSON » Sat Sep 06, 2014 8:31 am
big 2 smokers are bad about that the 750cc suzuki 3 cyl..could drive you nuts in slow traffic
if your running a bit rich can cause it ..the excess builds up in the crankcase then burns off and leans out ..
then does it again ...
Re: Surging ETZ 301
Postby Andy_C » Sun Sep 07, 2014 1:14 am
David.
Had a fiddle with the air screw and tickover speed and have all but eliminated the surging now, still does it a bit but is tolerable.
I also run a Kawasaki 500 Triple which dosent surge at all, guess as each pot is fairly small you don't get the problem.
Cheers.
Andy_C
Re: Surging ETZ 301
Postby DAVID THOMPSON » Sun Sep 07, 2014 9:04 am
some of the multi cylinder bikes have a hose from the bottom of one cylinder to the intake of the other
it cleans out the bottom end of excess fuel
there was no dealer in my area for kawasaki till after the2 and 3 cylinder 2 smokers had came and gone
so not sure how its plumbing works
kawasaki arrived late in my area
Users browsing this forum: Google [Bot] and 50 guests
