davegsm82 wrote:Is it the Plastic CEV clocks or the original round Metal (mechanical) ones?
Sometimes on the plastic ones the needle will swing right round the dial when you turn off the ignition, it's difficult to get it back round but one method I've found is to drill a small hole in the right hand side of the clocks, between the clear plastic window and the face of the dial, then poke a straightened out paper clip through the hole and swing it back around.
If it's the metal ones, then it's likely that the return spring is damaged or the little plastic peg has snapped off that stops it returning below zero. Sometimes an impact from the back can punch the whole mechanism up above the plastic peg too.
Dave.
davegsm82 wrote:It won't sort itself out, I tried switching the ignition on and off for about 10 mins once trying to re-create whatever glitch sent it round there in the first place.
Honestly, it's not all that hard to fix, 2-3mm hole in the side of the plastic case, go slowly so the swarf flies out the back, not into the clocks. paper clip, straightened out with a loop at one end (for grip) and a tiny 90-degree bend at the other. Just poke it through the hole and hook underneath the pointer, flick it back round and it should go back to where it belongs.
There's no return spring on these clocks, from what I remember, it just relies on the magnetic attraction in the motor mechanism, which is why it sometimes does this.
Dave.
Users browsing this forum: Google [Bot] and 28 guests
