ETZ 250 engine in TS 250/1 rolling chassis
Hi all !
I recently purchased a 1980 basket case (in a box) TS 250/1 with an ETZ engine badly fitted. The engine had a damaged crankcase so I completely rebuilt it as a matter of course. I carefully stripped the loom off the chassis and dickied up everything and am now at the stage where I have refitted everything but am trying to iron out the creases in the wiring as I don't know if the previous owner knew what he was doing with the wiring.
The wiring to the ignition switch is "as original" and it appears to have a regulator unit off a Jap bike (8 wires) badly spliced into it and it is uncertain if the bike ever ran with this setup.
I would like to know if anyone has any experience with using this type of regulator in this setup and if so, how do I correctly wire it. I am uncertain if it is a regulator/rectifier or just a regulator.
If you are interested, please follow this link to see images of my progress so far: http://s1109.photobucket.com/user/seani ... Z%20engine
This is a link to images of my generator and regulator: http://s1109.photobucket.com/user/seani ... g%20system
It's very frustrating as I have come so far and literally have only a few hours work ahead of me to have it running. If anyone out there could help me out on this one i'd greatly appreciate it _ AS IN _ WHAT IS THE CORRECT WAY TO WIRE THIS REGULATOR INTO THE SYSTEM THAT i HAVE ?
I have other questions regarding setting up the 2 stroke pump etc ... but i'd like to sort out the sparking and charging aspect first - by running it on premix until I iron out all the kinks.
Thank you for your time and ride safe !
