ETZ 250 owner . . . . again
Postby Lone-Wolf » Mon Nov 25, 2013 12:01 pm
Wotcha.
I'm new here, but have owned MZs in the past.
It all started off with aSupa 5 which sort of got me back into two strokes - I owned a few Bantams in my youth ( and have now come back to Bantams too ).
I rather liked the Supa 5, but preferred the 12 volt electrics and oil pump of the ETZ 250 . . . so I replaced the Supa 5 with anETZ 250
Things went well up to the point, when on Halloween 2009, some careless car driver almost took off my left leg. The resultant injuries meant my left foot no longer had any up or down movement - this is not a good thing if your gear lever is on the left. Sadly I sold the ETZ to a fellow bike club member, who incidentally still uses the bike on a regular basis.
Now in September of this year I was offered another ETZ. This one had been standing for quite a few years, but luckily the spark plug had been left in. I went and looked, and for the amount the fellow wanted for it, I couldn't refuse . . . . so out came the trailer and I once more became an MZ owner.
The engine had seized due to being left standing. I poured a mixture of diesel, penetrating oil, petrol and two stroke oil down the plug hole and left it for a day. The next day I heated the barrel with a hot air paint stripping gun and turned the back wheel with the bike in gear. Eventually it did the trick. A new plug and points followed. The carb was removed an thoroughly cleaned . . . a bit of fettling and the bike fired up. I even managed to get the clutch plates to free up.
The next thing was to make some kind of hand operated gear change. Using an old push/pull twistgrip and a few other bits I managed to get something that worked . . . . whether it will work well is another question.
Anyroad - enough of my rambling for now . . . . but be warned, there will be more to follow :lol:
Lone-Wolf
Re: ETZ 250 owner . . . . again
Postby Tony the Skin » Mon Nov 25, 2013 3:19 pm
Welcome from Lancashire. Looking forward to hearing more and perhaps seeing it.
Tony the Skin
Postby therealche » Mon Nov 25, 2013 5:19 pm
Gear change looks interesting! I know MZ actually made a hand gear change for the TS models, not sure about the ETZs
Once you get infected by the MZ bug, you never get rid of it!
therealche
Postby Lone-Wolf » Mon Nov 25, 2013 7:52 pm
therealche wrote:Gear change looks interesting! I know MZ actually made a hand gear change for the TS models, not sure about the ETZs
Wotcha.
I've seen the MZ hand change listed in the parts book . . . . it's very similar to the one I made for my Drifter. DRIFTER HAND CHANGE
The main problem with this sort of mechanism is the fact you have to use your right hand to operate the lever - when changing down a gear you can't blip the throttle, this results in a very clunky downshift and I don't suppose it does the gearbox any good.
Lone-Wolf
Postby Lone-Wolf » Mon Nov 25, 2013 7:53 pm
Tony the Skin wrote:Welcome from Lancashire. Looking forward to hearing more and perhaps seeing it.
Wotcha.
Oh . . . pictures will follow :D
Lone-Wolf
Postby Lone-Wolf » Sat Nov 30, 2013 6:16 pm
Wotcha.
Well the ETZ went for its maiden voyage today. The cable operated hand change worked . . . OK, it needs a little fettling, but the idea's a good 'un.
Sadly the bike never made it home. I suspect an electrical fault. I ended up having to get my VW trike and trailer and bring the ETZ home.
I will perform the autopsy tomorrow :D . . . .guessing a low tension wire off somewhere along the line.
Lone-Wolf
Postby therealche » Sat Nov 30, 2013 7:43 pm
Here's hoping it's something easy!
therealche
Postby Lone-Wolf » Sun Dec 01, 2013 8:21 am
therealche wrote:Here's hoping it's something easy!
Wotcha.
Right - pulled the fuel pipe off - plenty of petrol and it flowed freely. Took the plug out - nice healthy blue spark.
Put the plug back in . . . . .and the bike started first kick. Bloody MZs :D
I'll check over everything during the week.
Lone-Wolf
Postby therealche » Sun Dec 01, 2013 4:31 pm
See it just wanted some attention!
therealche
Postby Lone-Wolf » Sat Jan 11, 2014 6:29 pm
Wotcha.
Ah - back again. . . . .and another year to play with.
Now this 'ere MZ started up easily, but would only run for about thirty seconds before cutting out. Leave it a minute or so and it would fire up just fine - run for thirty seconds or so and stop again.
This had me scratching my head for a while, then I remembered something about fake NGK plugs - and I had treated the bike to a new plug - so out came the new plug and in went the original one. Bike runs fine now.
On the hand change front, it's looking like it's not going to work. If you set it up to give easy movement, then you have to rotate the twistgrip a good 90 degrees or so - if you set it up for minimal movement, then you have to put too much effort in and changing gear becomes hard work.
This calls for plan "B" - I'll see if I can find a way of making a crossover shaft and converting the bike to right foot shift.
All good fun eh ?
Lone-Wolf
Postby Lone-Wolf » Fri Jan 17, 2014 4:52 pm
Wotcha.
Here we go - the "scooter" type gear change didn't work all that well, so it was on to plan "B" - a right foot shift.
ETZ RIGHT FOOT GEAR CHANGE CONVERSION
So far, so good.
A full road test will follow . . . . . as soon as I get the bike on the road. :-D
Lone-Wolf
Postby Lone-Wolf » Tue Jan 21, 2014 12:13 pm
Wotcha.
Plan "B" was a success . . . .bike is now MOT'd and insured . . .only need to tax it and away I go :smt026
Lone-Wolf
Postby DAVID THOMPSON » Tue Jan 21, 2014 6:14 pm
the odd foot shift has a good effect on some one nicking it maybe he will get mixed up and hit
a brick wall
where i live they just steal 4 wheelers
enjoy the bike and stay warm till spring ...
Postby Eric Frith » Wed Jan 22, 2014 5:48 am
Try using Silkolene light gear oil for the gearbox, it makes finding neutral a whole lot easier.
Eric Frith
Postby Guesi » Wed Jan 22, 2014 7:32 am
Sounds like a synthetic oil.
This will kill the clutch :-)
Guesi Motorradteile
MZ spare parts
