ETZ forks and brakes ...
Postby Ian Hingley » Thu Nov 21, 2013 4:27 pm
Hi guys
I'm mulling over a winter project to fit a complete ETZ front end to my '66 BSA Victor, so I can get some better forks and a disc brake.
A few questions:
a) Are the front ends identical on the ETZ 125, 250 and 301?
b) Did the brakes swap between Brembo and Grimeca at some time? Which are best?
c) Anyone laced a 21" rim to an ETZ hub? I ride Long Distance Trials for my sins.
and
d) Anyone got a complete ETZ front end they'd like to exchange for some beer tokens?
Thanks in advance.
Ian
Ian Hingley
Bristol, UK
MuZ 660 Skorpion Tour
Ian Hingley
Re: ETZ forks and brakes ...
Postby arry_b » Thu Nov 21, 2013 5:14 pm
Ian Hingley wrote:Hi guys
A few questions:
Ian
Apart from the fork springs, yes for all practical purposes.
Ian Hingley wrote:b) Did the brakes swap between Brembo and Grimeca at some time? Which are best?
Calipers - Real Brembos were only fitted to early ETZ250s, and for not very long. They're badged Brembo. The MZ badged ones are a copy by MZ, and they're not quite as good, but not bad. Parts availability for both of the above is OK. There are no Grimeca calipers.
Masters - The Grimeca master cylinder is better than the original round MZ master, but spares for the Grimeca are more difficult to get hold of. Both work well on an MZ
arry_b
Postby Ian Hingley » Fri Nov 22, 2013 3:16 am
Thanks arry_b
Trying to build up a parts list in my head ...
Ian
Ian Hingley
Bristol, UK
Ian Hingley
Postby pmorris4562 » Fri Nov 22, 2013 3:43 am
I don't want to rain on your parade, but MZ forks are quite difficult to get hold of, for the same reason as you are looking := pre 65 trials. Everybody wants them, but if you do manage to source a pair, good luck with the conversion! :)
1993 SilverStar, 1991 ETZ301
pmorris4562
Postby Ian Hingley » Thu Jan 09, 2014 9:50 am
Hi
I've sourced an ETZ front end (well, a complete bike actually) via fleabay.
I need to use the BSA fork stem with the MZ yokes as it is the correct length for the headstock and correct diameter for the bearings.
How do I remove the MZ fork stem from the bottom yoke? I don't want to go bashing it with the BFH if it's threaded in ...
Cheers
Ian
Ian Hingley
Bristol, UK
Ian Hingley
Postby Old Dog » Thu Jan 09, 2014 10:30 am
Starting from the top, the fork leg is held in but the large shouldered nut at the top which screws into the thread inside the stanchion.
Then you have the lower fork clamp on the tree, then out she comes.
The bottom of the leg is held in place with a nut underneath (turn the leg upside down and you'll see it) 10mm spanner from memory, which threads onto the inner.
good luck
All the best
Old Dog
Old Dog
Postby Ian Hingley » Thu Jan 09, 2014 11:58 am
Hi Old Dog
Thanks for that.
I've already dropped the legs out of the yokes and removed the yokes from the headstock.
My issue is how do I remove the centre stem (linking the two yokes) from the bottom yoke? Is it a press fit, threaded or ...?
Cheers
Ian
Ian Hingley
Bristol, UK
Ian Hingley
Postby Old Dog » Thu Jan 09, 2014 12:14 pm
Large nut on top and the drift from memory, I am hung up (lost nerve) on putting baby TS motors together. You need a manual - you can get them online from the MZ club.
I might have one soft somewhere, even a haynes would do.
All the best
Old Dog
Old Dog
Users browsing this forum: Google [Bot] and 25 guests
