Shock Absorbers - again
Postby stuart-glos » Sun Oct 07, 2012 2:41 pm
I made some soft jaws for my vice and managed to unscrew the top mounting ring - but needed a big hammer to get it to move!!
I made a tool (a bit crude) but it worked and the screw top of the shock absorber body came off fairly easily.
I did that on 2 different MZ shocks and expected to be able to remove the internals - but it's all stuck solid. The damper rod moves up and down freely but whatever is in the body of the shock won't budge.
Any ideas please?
ta
stuart
stuart-glos
Re: Shock Absorbers - again
Postby den » Sun Oct 07, 2012 3:56 pm
is there a screw at the bottom ,where the wheel spindle fits,maybe hidden??..just a guess
den
Postby therealche » Mon Oct 08, 2012 6:28 am
Dunno, but while we are waiting for those that have to return, have you screwed the top mounting ring back onto the damper rod to give you a better purchase? My gut feeling is that more brute force is required, but then again those that know me will tell you that is my usual response to problems!
therealche
Postby DAVID THOMPSON » Mon Oct 08, 2012 10:25 am
they may have taken a clue and did the USA trick
make it self destruct if you try to take it apart
Users browsing this forum: Google [Bot] and 37 guests
