TS250 rear wheel.
TS250 rear wheel.
Postby Gwiz » Tue Jun 05, 2012 10:29 am
Never having owned one of these beasts in the past, I wondered if anyone could answer a question.
The rear wheel on my TS250 has a minor amount of play. Having the bike on it's centre stand so that the rear wheel isn't touching the ground, If I grab the top of the tyre and wobble it back and forth, I seem to have about 2mm of play from, I suspect, the bearings.
Is this normal for one of these (as in "They all do that, mate")?
You gotta laugh.
Gwiz
Re: TS250 rear wheel.
Postby radiograf » Tue Jun 05, 2012 10:36 am
No, sounds like the rear wheel bearings are shot. However, MZ rear wheels are mounted in an unusual way, the rear axle does not pass all the way through as on a Jap bike, but screws into the cush drive. This allows you to remove the rear wheel without touching the chain, so I would try tightening it up first.
radiograf
Postby Gwiz » Tue Jun 05, 2012 10:47 am
Thank you for your prompt reply :D
I have done it up pretty tight, so it seems you have confirmed what I thought. I'll leave it be for the moment and concentrate on the engine.
The "MZ shop" will be getting another order from me then........
You gotta laugh.
Gwiz
Postby DAVID THOMPSON » Tue Jun 05, 2012 1:56 pm
as in the above post the way the wheel mounts is odd to all others i have worked on..
the right side sets the chain in place then the left side goes in ..
do check all the parts
the bearings may be bad ..but also the axle may not be all the way tight
or some one may have spacers in wrong or an extra washer added
Postby therealche » Tue Jun 05, 2012 4:29 pm
The bearings are a standard size ( the code escapes me at the moment) and they are cheap as chips from any bearing supplier
therealche
Postby therealche » Tue Jun 05, 2012 4:32 pm
6302 From simplybearings.co.uk the cheap unshielded bearings are £2.29 + vat with £1.50 P&P.
therealche
Postby Gwiz » Wed Jun 06, 2012 12:59 am
Now there's cheap!
I'll order a couple this week.
Thank you gentlemen for your help. :D
You gotta laugh.
Gwiz
Postby chromedome » Wed Jun 06, 2012 12:24 pm
Simply Bearings are a joy to deal with from my experience.
chromedome
Postby therealche » Wed Jun 06, 2012 12:49 pm
chromedome wrote:Simply Bearings are a joy to deal with from my experience.
I'll second that. Ive just ordered some weird and wonderful bearings from them. Not worth waiting at my local bearing factors, who always have to order 1 item in!
therealche
Postby radiograf » Wed Jun 06, 2012 5:00 pm
Get the bearings with the rubber seals fitted (6302 2rs) as these come pre greased, and reduce the need for seperate seals. Of course you can fit seals for even more protection.
To lengthen the life of your bearings never jetwash them, as this will wash the grease out, even the sealed ones.
radiograf
Postby Gwiz » Fri Jun 15, 2012 12:16 pm
Bearings bought, bearings fitted, wheel has no wobble.
Cheers guys. :)
You gotta laugh.
Gwiz
Users browsing this forum: No registered users and 55 guests
