ts 150 carb question
Postby ghostinthemist » Sun Apr 15, 2012 11:48 am
there is a small rubber grommet at the bottom of the choke does it seat into the choke plunger or mearly sit at the bottom
ghostinthemist
Re: ts 150 carb question
Postby therealche » Sun Apr 15, 2012 12:23 pm
It should be seated in the plunger
therealche
Postby ghostinthemist » Sun Apr 15, 2012 5:56 pm
so far found an old spiders nest in bottom with plunger tons of bugs! Looks like some water got to sit in there with some dirt and crap too and the float sounded like a maraca! Well after 40 minutes in some lime away and some jb weld we'll have her going strong in no time! Going to replace air filter with 2 used laundry sheet. Did a intake ratio test and the draw was the same.
ghostinthemist
Users browsing this forum: No registered users and 39 guests
