TS 150 Clutch Conversion
Posted: Mon Jul 18, 2011 10:48 am
Have fitted a clutch from an etz model (one circular clutch spring as opposed to normal ts clutch) this gives a lighter clutch action. There is one modification needed as the clutch is deeper than the original a hole has to be trepanned in the clutch casing to take this into account and a plate put over the hole. Works a treat !
