74 es250 steering/washer thingy??
Just pulling apart my recently acquired 74 es250 Trophy.Installing new wiring loom and treating her to a full respray,anyway.Was taking apart the front end and a part of something dropped to the floor,looked similar to a bit of brake shoe/pad friction material but was obviously part of a ring shaped washer/spacer.Found out it was from the top half of the steering column,is this part available anywhere?It sits in between a large metal washer and the steering column tube on the frame,thanks!
