Newbie on the scene of Mz's
Hey all, my names luke,Im 17 and I have a 1984/5 ( cant remember
) etz 125. Ive had it for 7 months know and I have had ALOT of break downs, from rubbish in the carb to not starting to electrical problems, points etc.
The rubbish in the carb is sorted out know, ive fitted a 2nd in-line fuel filter,cleaned the carb out far to many times that Id like to remember lol the points and condenser are replaced but I still have this problem
Its not charging the battery? However this is the catch, when you put a meter over the battery when its running it shows 12volts and when you rev it up around 14 volts so its charging?
The battery was new around 5 months ago and have never been run flat??
second problem, popping and farting but only ocasionally
its only when you open the throttle it does it and can be a little dangerous if your overtaking as its quite a violent jolt
The plugs burning perfect, the pistons perfect, the bore is perfect and smooth ( no lip) so I am at a loss with it to be honest
Has anyone got any idea's what my problems could be?
thanks in advance
luke
thanks in advance
luke
