Oil Guide Discs ETZ
Oil Guide Discs ETZ
Postby Les H » Thu Nov 19, 2009 11:28 am
Hi everyone. I have managed to separate the crankcases and have stripped down the rest of my Saxon 301 engine.
I am baffled by the metal discs that are inboard of the crankshaft oil seals and are next to the crankshaft main bearings. I realise these discs guide the oil into the ball bearings, but the discs have a small dot of metal near the edge that has to be lined up with the oil delivery hole. As the discs are simply steel discs with no other difference anywhere around them I am intrigued why it matters that they have to be lined up in a particular way. Does any one know? I cannot see why it should be so, I look forward to any ones idea on this. Many thanks.
Les H
Re: Oil Guide Discs ETZ
Postby djsbriscoe » Thu Nov 19, 2009 5:11 pm
Have you got any photo's or pages from a workshop manual to describe what you mean?
Thanks.
David
Electronics tech by trade.
djsbriscoe
Postby Les H » Sat Nov 21, 2009 5:22 am
http://www.mz-b.com/k251/251t44.htm
Part no: 14 shown on the crankshaft diagram. or MZ part no: 29 43 105
Thanks.
Les H
Postby djsbriscoe » Sat Nov 21, 2009 10:13 am
I've just watched this video
http://www.youtube.com/watch?v=oIh2Zm2J4Ss
and from what I can gather the punch mark probably creates a deformation in the disk that allows the oil to be channeled towards the bearing races. Also the plate is placed so that the central part of the it (which is curved) can form a kind of well for the oil.
The next video in the series is
http://www.youtube.com/watch?v=DqHKG-WC ... re=related
Which may explain it a bit more as well.
HTH.
David.
djsbriscoe
Postby DAVID THOMPSON » Sat Nov 21, 2009 10:57 am
what am information gold mine for the 250/251 owner
does any one know if that series of movies is available
some where on dvd
the speed of my internet down load makes it hard to watch
the beauty of the 250/251 is it's easy to fix and if not beat and thrashed
would make a very good daily driver
Postby manumensa » Sat Nov 21, 2009 5:13 pm
DAVID THOMPSON wrote:does any one know if that series of movies is available
some where on dvd
Thompson, I can make a CD copy for you.
Please, send me your address.
Saludos/Regards
manumensa
Postby Les H » Sun Nov 22, 2009 5:58 am
David, if you read my previous post: Crankcase separation MuZ 301, you will see that we discusses the source of these videos at MZ owners club Hungary. You will then be able to view the complete set. They are all excellent.
Looking again at the rebuild video, I am now confused what way round the discs fit. The witness marks on my used discs indicated that the dishing faced outwards but the video makes it appear that you fit them with the dish facing inwards, but this could be an illusion. Does anyone know for sure what way round they fit?
My theory is that the small cenre punch pip stops any chance of the disc rotating. If it starts to turn in sympathy with the rotating bearing, the pip will hit the open end of the large retaining circlip and will remain stationary. This will only work if the pip faces outwards towards the circlip. Is anyone with me on this idea? I dont think the pip is used for oil guidance but I could be wrong.
Les H
Postby djsbriscoe » Sun Nov 22, 2009 6:37 am
Yes, youre probably right, it probably stops the plate from turning and has nothing to do with oil guidance.
David.
djsbriscoe
Postby DAVID THOMPSON » Sun Nov 22, 2009 6:19 pm
if it spins then the oil will build up at the bump and be slung off in a even manner
Postby Les H » Mon Nov 23, 2009 3:49 am
Just to say that after many repeated replays of the oil disc fiiting in the video, I can be happy that the pip on the disc does indeed face or protudes outwards and can be trapped by the circlip ends if indeed any turning was to take place.
As an additional point, it seems difficult to see how any amount of oil can get to the main bearings as they are shielded and in flush contact with the oil disc. Very odd indeed! The only way I can see is that oil collects in the outer space between the disc and the oil seal which eventually fills up with oil to the level of the shaft. The oil then somehow gets past the tiny clearance between the shaft and the centre hole of the disc and eventually gets to the bearing centre and is then circulated in the bearing.
It works though.
Les H
Postby djsbriscoe » Mon Nov 23, 2009 6:44 am
There must be some deformation of the disk around where the punch mark is. It's probably enough to allow some of the oil that comes out of the oil drilling in the crankcase to flow into the edge of the bearing. The bearing on the video is only sealed on one side isn't it? The side without the seal faces the plate I think.
Anyway, as long as it works it should be OK.
David.
djsbriscoe
Postby Les H » Mon Nov 23, 2009 12:31 pm
Sorry David, the way I constructed my sentance looks like I suggested the bearing was a sealed type. I didn't mean to say that. What I should have said and made clearer was that I considered the outer face of the bearing was in such close contact with the oil guide disc there was little chance of oil getting to it directly from the small hole feed hole. But the bearings last well so they must be getting some oil.
Les H
