Hi a few questions about etz125 from a newbie
Postby bastios » Wed Oct 28, 2009 4:27 pm
Hello all, ive just aquired a 87 etz 125, what a peice of kit..... now i was wondering if you guys could answer a couple of questions for me, it came with no battery, is it 6v or 12v? i counld look at the bulbs but this is easier lol, does it run pre mix or is the a seperate oil tank? if so would it still be 25-1? and the carb needle was out, do we know what the setting should be? there is four indents for the clips?? thanks guy
bastios
Re: Hi a few questions about etz125 from a newbie
Postby djsbriscoe » Wed Oct 28, 2009 5:55 pm
The battery is 12 volts. The engine lubrication is pump fed if there is a black tank with a red cap underneath the left hand (nearside) side panel. If there is no tank the oil is mixed in with the petrol at a ratio of 50:1 (1 litre oil to 50 litre petrol). There should be a steel measuring cup with level markings attached to the underside of the petrol tank filler cap. If the bike is an newer model there will probably be a locking petrol cap, so no measuring cup. Needle position try second from top as a start and move the clip up to lean the mixture or down to enrichen it as needed.
HTH,
David.
Electronics tech by trade.
djsbriscoe
Postby bastios » Thu Oct 29, 2009 1:58 am
thanks david for you reply, top bloke
bastios
