indicaters
indicaters
Postby chris1986 » Tue Jul 08, 2008 2:10 pm
my indecaters have just stoped wrkin, the rest of my lights work. is there a relay or do i just need new indicaters
chris1986
Re: indicaters
Postby manumensa » Tue Jul 08, 2008 3:53 pm
fuse, relay, handlebar switch, wire... :?:
manumensa
Re: indicaters
Postby DAVID THOMPSON » Tue Jul 08, 2008 4:43 pm
he forgot the plugs that plug wires together there a pain on most all bikes
Re: indicaters
Postby Nozz » Tue Jul 08, 2008 8:50 pm
I'm guessing we are talking about what some of us call "Turn Signals", and there is a relay under the seat that has given me problems from time to time. I have found that problems are usually caused by a ground/short problem when only one side is affected, but the relay has acted up and caused it not to work at all. I would take a look under the seat and check for shorts. The switch on the handlebars seems pretty simple and failsafe, so I doubt that is causing problems. I think I would be sure your bulbs are all OK. Good luck!
Nozz
Re: indicaters
Postby chris1986 » Mon Jul 21, 2008 5:59 am
found and fixed thanks
chris1986
Users browsing this forum: Google [Bot] and 40 guests
