TS250 indicators
TS250 indicators
Postby sidewaysid123 » Thu Sep 28, 2023 1:14 am
Can anyone tell me why the left hand pair of indicators flash normally, but the right pair flash at 2 times the speed, I have 6 volt 24W bulbs in
sidewaysid123
Re: TS250 indicators
Postby DAVID THOMPSON » Thu Sep 28, 2023 3:10 am
some bulbs flash at different rate its got wrong bulb in 1 side
Postby Gerryman Ts125 » Sat Sep 30, 2023 3:08 pm
I had 6v 21w indicator bulbs in the front of my Ts 125 but had 12v 5w in the back. And they all flashed at the same rate. Maybe your flasher unit is failing.
Have you tried changing the bulbs around? Sounds strange though.
Gerryman Ts125
Postby sidewaysid123 » Sun Oct 01, 2023 4:08 am
I very much doubt that bulbs flash at different rates, it has got to be the current feeding them that is arriving and ceasing at a quicker rate, I think I will change the flasher unit.
sidewaysid123
