TS 250/1 Neutral Selection
Postby MZFred » Wed Apr 27, 2022 4:26 pm
Has any one had issues selecting neutral from 1st gear when coming to a stand still and if so how have you resolved the issue?
The gears selection is ok up and down through the box but but unless I select neutral from 2nd gear when coming to a stop it is near impossible to select neutral from 1st gear. I have set the clutch cable adjustment as per manual and even altered the gear pedal to obtain best position for me but to no avail.
Any advice/recommendation would be greatly appreciated!!!
MZFred
Re: TS 250/1 Neutral Selection
Postby DAVID THOMPSON » Wed Apr 27, 2022 9:26 pm
the lever is not stroking the cable far enough it may have got bent
had yamah ym1 do it to me years ago the lever was bent
and not pulling cable far enough
Postby Blurredman » Thu Apr 28, 2022 2:31 am
Sometimes it can depend on the oil used. I've had oil in the past where when the engine was cold the gearbox JUST WOULDN'T SHIFT. But when warm it was fine..
1987 MZ ETZ300 - 38,000 miles
Postby Puffs » Thu Apr 28, 2022 4:01 am
Postby lavrentyuk » Thu Apr 28, 2022 8:20 am
I've had a few MZ 2Ts do it. My current one is, even with a spanking new clutch in.
I usually use Silkolene Light Gearbox oil, but am tempted to go even lighter. I've even used ATF in the past.
Because of the way the oil pump is driven I really don't like sitting somewhere with the clutch in for long.
Richard Marshall
Wales, U.K.
lavrentyuk
Users browsing this forum: No registered users and 52 guests
