MZ ES 250/1 electrical , spark plug, ignition and charging
Hello,
My bike, am ES250/1 1962 was neglected for a long time by me and finally now we got reunited and I start the restoration.
One of the questions I have now is about spark plug.
Initially , 15 years ago someone put a long sleeve spark plug inside which did not fir to the factory specs. It also looks very burnt.
Look at the pic:
One of the mates here observed that the plug is too long so I took head off and here is how it stays in the combustion chamber:
This is how the recommended ngk b8hs stays:
and this is what I found that a plug should stay:
https://www.cyclepedia.com/manuals/onli ... 235413.jpg
So neither plugs stay in the correct location???? I have 2 heads, in both of them the plug reach is the same.
Beru ZM14-260 isolator spetzial has a reach of 12,5 mm and ngk B8hs has a reach of 12,7 mm.
Anyone with any experience on this subject?
Can someoane measure a head and tell me the lenght of the thread, maibe both of mine have been altered. No mine have 15mm thread lenght.
With the recommended plug the engine seems less noise and more "round" running.
The specs of the Beru Isolator ZM14-260 are the same in terms of dimensions as the NGK B8HS.
I will put and auto oscilloscope on the bike and see how the primary wave and the secondary burn wave look with both plugs installed and will post.
Until than any advice is very welcomed.
Look at the pic:
