Andy_C wrote:Guesi - partly agree with what you say, correct timing is the most important issue.
So it follows that anything that can be done to keep the spark accurrate has to be a good thing, which the electronic module should do as it should reduce points erosion.
"Fatter spark" - surley a better / "fatter" spark has to be a good thing.
If you want to light a fire it usually starts better if you have a decent source of combustion, i,e, a "fatter" spark.
Puffs wrote:
Guesi, would you know more about this; would you have an advance curve for any of the commercially available electronic ignitions for the TS/ETZ?
Puffs wrote:Hmm, a Jawa 350 (6v system) with a 12v battery. How does that work? How do you charge a 12V battery with a 6V dynamo?
Andy, yes erosion will impact the timing, but only on the somewhat longer term. It's not a major problem for a standard MZ, but vibration & clearance cause inaccuracies in the opening right from the start, and that's where an EI brings benefit, particularly in the higher rev range.
On the strength of the spark: it really only has to ignite the gas right around the plug's electrodes, physics does the rest. And visually stronger need not necessarily bring you a lot, see also https://www.powerdynamo.biz/eng/info/spark.htm .
Users browsing this forum: No registered users and 41 guests
