TS 125/2 Oil/Fuel leak from exhaust?
'Allo all, was wondering if you could advise me on why my TS 125 Two Stroke is leaking oil from the exhaust? It's not leaking from the end, but rather from the point adjoining the pipe coming from the engine and the exhaust proper.
this is just an example image to show where the leak is, my bike is not this clean or nice looking.
there's a couple of other things that bother me too, the throttle twist grip is held in place by a phillips head screw that likes to sometimes rip itself out if I lean too hard to one side. would it be alright to just drill a larger hole into the handlebars and replace it with a proper bolt?
more serious is that the seals on the engine may well be going, according to a mechanic I took it to I have air leaks into the engine. He adjusted it to rev lower, and it will pass an MOT (once I have sorted some other things on it) but once I have the dosh I really need to look at replacing this engine or repairing the crank seals and maybe bearings too.
Anyway all problems aside it it's a great bike and I can't wait to get riding on it!
Cheers much,
-Luke.
Cheers much,
-Luke.
