Dim indicators
Dim indicators
Postby spooky » Sun Nov 01, 2020 5:19 am
Now I have a new battery and so far it seems fine, I want to get my indicators working properly. They do light up but are all very dim, there is a buzz from flasher relay when they are working , is it in need of replacement or is there something else that could cause weak flashing ? poor earth maybe ?
RE classic 500, 1951 Terrot etd, 1970 Gilera Autostrada, Vespa T5 and the Black Pig !
spooky
Re: Dim indicators
Postby DAVID THOMPSON » Sun Nov 01, 2020 8:32 am
clean the bulb base some of the metal can get a coating that's a bit dirty looking
and the tip needs cleaning
and sometimes the bulb used is not a very bright one
Re: Dim indicators
Postby spooky » Sun Nov 01, 2020 9:32 am
Managed to get three working a bit brighter, cleaned bulb fittings, but the fourth one will have to wait until I take the pannier off to get to the screws...thanks :D
spooky
Re: Dim indicators
Postby Puffs » Mon Nov 02, 2020 4:19 am
Re: Dim indicators
Postby spooky » Fri Nov 13, 2020 6:29 am
replaced front pair with some honda ones, very much brighter, i will mount the other matching pair on a bracket fastened to the back light mount..
spooky
