MZ TS250 74' new piston and bore
Postby DARKEST » Fri Jan 24, 2020 12:53 pm
Hi
I just found this forum and is very happy for that as it seems to be a place for help and guidance.
I have a MZ TS250 74' where the piston is worn out an so is the barrel bore. I would like a new piston and a refurbished the bore on my cylinder barrel. The present piston diameter is 69.47mm. I have some questions before I purchase a new piston and make arrangement with a bore shop.
1. Is the next size 70.0mm? (there are only small scratches in the bore)
2. What type of piston should I chose? I can read that the original piston K20 is preferred as the temperature expansion koefficient is smaller and suit the recommended tolerance of 0.04mm between bore and piston. What is the original piston? HAL, KAL, Megu, Almot?
3. I can read that the tolerance is 0.04mm between the piston and barrel. This should give a distance of the piston rings ends of 0.2mm. This is very precise and is it even possible to do this? - or is it just piece of cake for a bore shop?
4. I assume the first thing I should do is to purchase a new piston and give it to the bore shop with my preferred tolerance?
5. After finishing the new bore the ports should be finalize with a chamfering right? A good bore shop would do that?
Your experience will be appreciated.
Thank You
/Brian
DARKEST
Re: MZ TS250 74' new piston and bore
Postby Guesi » Sat Jan 25, 2020 1:16 am
I would prefer an original piston. The Almot have no good reputation.
Megu or HAL are the original producers.
Price for an original piston is 79 Euro.
Guesi Motorradteile
MZ spare parts
Postby Puffs » Sat Jan 25, 2020 7:17 am
Welcome Brian!
1) Yes. But it is a bit difficult to judge if you need a rebore to that next nominal size, from 800km distance. Measure it, or have it measured.
2) As guesi says. The Polish Almot is NOT original.
3) Maybe, yet a good workshop can work to those tolerances. Be very clear with the guy, maybe give him a printout of the relevant page from the manual. If preferred (in DK), manuals in German from miraculis.de.
4) Yes, a/a. Best not buy Chinco or Indian PoS, quality only hurts once.
5) Yes. And/or you too. Be very sure the barrel is clean before you mount it on the bike.
Good luck!
