First ride TS250
Finally after fixing the oil leak on my four speed TS250 I decided to take it for its first ride. Only travelled a mile or so but that was enough to determine that there is a lot more fettling to do before I take it for a long run.
The clutch take up was not very smooth, the front end felt a bit unstable (need to check wheel bearings and head race adjustment) the front brake was not up to scratch and the footrest bar did not feel correct as if it was bent slightly giving an odd riding position. It takes at least 30 mph before the charge light goes off. Engine was quite rough at low revs but smoothed out nicely with higher revs.
It's definitely not how I remembered my new 1974 TS250 but the poor girl is over 40 year old now. I'll get her sorted over the next few weeks.
BTW does anyone know where I can buy a new rubber clutch cable cover that the clutch cable passes through and then goes over the tube sticking out of the clutch cover? Cheers Michel
