2 Stroke Oil for TS250
Postby veloce2003 » Wed Sep 11, 2019 2:41 pm
Hi, can anyone recommend a suitable two stroke oil to mix with petrol for my TS250? Thanks Michel
veloce2003
Re: 2 Stroke Oil for TS250
Postby Puffs » Thu Sep 12, 2019 5:49 am
AFAIK, the DDR was not known for producing magnificent oils, so their bikes have relatively low demands; any two stroke oil should do. But watch out: two stroke oil, do not use engine oil or gear oil to premix!
In my low-powered 2T's I'm using a decent semi synthetic, in order to reduce carbon build-up & smoke. I'm currently using Mannol 2T+, which I understand many use in their MZ's.
Postby veloce2003 » Thu Sep 12, 2019 9:34 am
Thanks Puffs I'll check it out Cheers Michel
veloce2003
