Puffs wrote:Thanks; 0.06mm might be on the tight side for that piston, be careful the first 1000km & vigilant of any signs of sticking. On the other hand, I don't really know the clearance you can run this particular piston at, so it might well be that 0.06mm is fine. FYI, 0.05mm is what is advised for the original pistons in K20 alloy, 0.06mm for Almot's in K20 (less accurately made, yet from the proper alloy), and 0.07mm is a typical clearance for a €200+ racing piston.
Did the fuel go into the crankcase?
The exhaust says it had been waiting a long time for things to come. Normally they rot on the outside, in a 2T with oil in the fuel.
parrbd wrote:A couple more setbacks
For reasons too complicated and not really interesting enough to post here; I was unable to access my bike for about 24 hours after I created that video. In that time the entire litre of premix drained from the leaking fuel tap. When I could access the bike again, I tried to restore the fuel tap with some miscellaneous O rings that I had laying around. This made it leak worse. . I hoped one of my BMW taps might work but they're bigger.
I found the O ring used on my DR650 oil filter was the right size for the ETZ fuel tap.
Blurredman wrote:Any news on your gearbox?
Puffs wrote:Good you're making progress!
What is this 'jig'? Can you show a pic?
