dot 3- dot 4 brake fluid 1989 etz 250
Postby tynsham » Mon Mar 29, 2010 3:46 am
i live in new zealand and cannot find dot 3 brake fluid for my 1989 etz 250. it states on fluid reservoir cap use only dot 3 brake fluid, i have seen castrol dot 4 fluid that states it can be used instead of dot 3 but it also says that if it is advised that vehicle can only use dot 3 fluid do not use it. if i use this dot 4 fluid could it harm rubber components in the brake system. would be very grateful if anyone could help..
tynsham
Re: dot 3- dot 4 brake fluid 1989 etz 250
Postby Skorpion » Mon Mar 29, 2010 8:51 am
Hi tynsham,
Yes Dot4 is ok to use as it is fully compatible with Dot3.
http://www.castrol.com/liveassets/bp_in ... SPDOT4.PDF
I think maybe some silicon and definitely mineral based should NOT be used.
Skorpion
Skorpion
Postby tynsham » Fri Apr 09, 2010 3:22 am
ok - thanks. dot 4 it is then...
tynsham
