by nikitino » Sat Jun 27, 2009 4:12 pm
Is there any trick to removing the rear wheel on a Country 500 (probably same for saxon tour). Does the odometer cable just unscrew from the rear sprocket/chain guard? Also, the axle seems a bit funny......each side has a nut that turns independently of each other.....the manual i have says something about taking off the nuts and then pushing the bolts in or something but i'm not sure i understand......it's different than say a a dirt bike axle which is just one long bolt with one nut on one end.....any pointers on this?
nikitino
