mz 125 sm, several problems
Postby biohazzardz » Wed Dec 25, 2013 1:08 am
i just picked up my first mz, its a 125 sm and it is currently very far from its original factory condition
several things have been changed/removed
radiator hose has been changed to a braided line
airbox was removed
battery has moved
electrical and components have been moved around
carb was changed to a flat side carb(changed back to the original vm24 because i couldn't go past half throttle without the engine dieing)
as of right now it has several problems,
ocassional gear slip( it will slip back into the previous gear)
battery doesn't seem to get a charge, i can start and ride for a while(about 50 miles) then it won't start or will slowly die and stop firing the spark plug and the bike will misfire and die.
I'm new to the mz line of bikes and would greatly appreciate if anyone could help me fix this bike to get it in a usable condition.
biohazzardz
Re: mz 125 sm, several problems
Postby biohazzardz » Wed Dec 25, 2013 1:10 am
box of parts that came with the bike
biohazzardz
Postby DAVID THOMPSON » Wed Dec 25, 2013 3:06 pm
you have your work cut out for you
i hate it when a nice bike is owned by a chronic modifier
check the voltage regulator/rectifier unit mine died on day 2 yes at about 30 miles
also have suffered from a bad bunch of fuses over the years
see the relay 19 problem notes
and get the carb back to stock
and the air box and filter on it
the boys at the factory had this thing reliable and running strong
all the mods i have seen make it run slower use more fuel or just plane not run
there are 2 relays on this bike one is relay 19 it works with the side stand switch
and there is an other some models its back by the tail lamp and others its under the gas tank
easy way to find it is get a helper with good hearing and turn on the key while listening
for the clicks as it goes on and off
these go bad as the contacts are to small for the load they run through them
and when there bad they cause all kinds of stuff to not work
they can be replaced by a auto relay used in cars to switch extra lamps
questions ask
nice daily driver
Postby biohazzardz » Wed Dec 25, 2013 3:17 pm
do youthink having a k&n air filter on the stock carb would affect it much, since the previous owner welded steel plate where the air box should go to hold the battery
biohazzardz
Postby DAVID THOMPSON » Wed Dec 25, 2013 6:54 pm
you can adjust the filter but finding things to get the carb adjusted will be hard ..
if the air-box is still available i would torch and grind the frame back to stock
i only change handle bars or the seat so i can get my feet on the ground.
i will confess to modifying ssb cb radios to 10 meters for ham radio use
but i try to leave the bikes stock
Postby biohazzardz » Wed Dec 25, 2013 7:51 pm
changed the main jet on the vm24 to cope with the filter change and seems to be running fine, the relay 19 seems to be covered in a turquoise corrosion on 2 of its connections. I'm going to look for a replacement tomorrow when stores are open.
so a bad voltage reg could be the cause of the battery somewhat not charging?
biohazzardz
Postby DAVID THOMPSON » Wed Dec 25, 2013 9:32 pm
the battery may be toasted
i will look at the size in my rt125 its bigger than stock but has to be removed to check the water
Postby biohazzardz » Thu Dec 26, 2013 12:55 am
i actually replaced the battery after it first died on me, i had a spare 12v 9ah battery still brand new in box
biohazzardz
Postby DAVID THOMPSON » Fri Dec 27, 2013 12:16 am
9ah is a bit of a wimp i run 14 ah and it starts but you got to play with things ..like the plastic side cover
gets modified but for a good useful cause
i never saw a bike that did not need a bigger battery :smt040
Postby biohazzardz » Fri Dec 27, 2013 1:23 am
ill have to try that out, i just want this mz running, its a good looking and fun bike for around town use... until the battery runs out on me
biohazzardz
Postby XCalsteRX » Mon Dec 30, 2013 6:30 pm
Hello Bio, my RT hasn't been starting off the button recently, thought it was a problem with the battery turned out it wasn't at all after charging and checking the voltage with a meter. I've just now adjusted the choke cable near the handle bar almost fully out, with this done I pulled the choke to fully on, took the charger off the bike and then turned it on, pressed the button and fired right up! So I'd recommend you to try this also, a tip..you may have to twist the throttle fully open whilst pressing the starter button, then switch the throttle off whilst still holding the starter button and it should crank harder and hopefully turn the engine over! I'll keep you updated if it works in the morning to after being off charge for 12 hours.
XCalsteRX
Postby DAVID THOMPSON » Mon Dec 30, 2013 10:18 pm
mine will not start from cold with any throttle at all the slide has to be shut
when warm it refuses to start if any throttle is applied..
probably varies from bike to bike
and mine hates gas with ethanol in it
mine is still setting on the parking pad out front so i will see how it goes tuesday
things just do not seem to get done in a timely manner around here
need to put the bike away and the mower
yuk its almost January
Dave
Postby biohazzardz » Mon Dec 30, 2013 11:44 pm
its not that it doesn't start, its that the battery literally slowly dies as i ride(hooked a small voltage reg as i was riding) its to the point where i can get it running with a bump start and it will idle with 7volts but if i try to pass 2000 rpm it doensnt have the power to the ignition coil and the bike flat out dies.
biohazzardz
Postby michael » Mon Feb 10, 2014 6:50 am
there are two possibilities :
- the connection between the red wire coming from the regulator/rectifier is wrong, clean it
- the regulator/rectifier is out of order or the connexions are wrong, first clean connexions
to find help you can download the repair manual for SM there : http://www.sendspace.com/file/q9pgh0 (notice entretien MZ 125 SM SX.pdf (7.58MB))
you can download the 2005 RT shematic diagram there : http://imagik.fr/view-rl/74762, the same for SM exept there is not counter on SM
the colors on the picture are not true, I done them to find easily where each wire is going, the real colors are written ... for example Rt/Sw mean Rot /Shwartz (= red/black) it's in German (sorry), and explanations in French (sorry too)
you'll find explanations about regulator/rectifier on page 125
sorry for my bad english I'm French
michael
Users browsing this forum: Google [Bot] and 144 guests
