How to adjust the head bearings?
Postby jawzx » Wed May 11, 2005 6:36 pm
My 2002 SM has developed a hint of head shake, its obvious at 120 KPH, but if you pay attention it's noticable even at 60-70 KPH. I know on many bikes you can tighten up the head bearings with a collar located between the upper tripple-clamp and the head. The SM doesn't seem to have such a ring, unless it is located underneath the bearing end-cap. Does anyone here know how one goes about tightening the head bearings on this bike? :smt100
2002 125-SM
jawzx
bearings
Postby DAVID THOMPSON » Wed May 11, 2005 10:44 pm
there ball bearings not tapered
and check the rear wheel linement the tail may be wagging the dog
also air in tires and funny tread wear on front
my oem front tire is a bit funny as i ran it under inflated
for a bit :D
aha!
Postby jawzx » Wed May 11, 2005 10:49 pm
that explains the lack of adjustment collar...
Will do the suggested, thanks.
2002 125-SM
jawzx
Rear wheel!
Postby jawzx » Mon May 16, 2005 7:28 pm
well my rear wheel wasn't visibly off, but I checked it with a tape measure (and adjusted my chain at the same time) VIOLA! no more shake. thanks!
2002 125-SM
jawzx
