rt 125 rear brake caliper ?
Postby DAVID THOMPSON » Thu May 02, 2013 8:33 pm
anyone know the number for a replacement rear caliper
prefer a brembo
the G crap has died it never worked very good
or a link to the brembo book of pdf drawings
of calipers
Re: rt 125 rear brake caliper ?
Postby DAVID THOMPSON » Sat May 25, 2013 11:19 am
i found this
brembo 10.4776.83
it looks like my master cylinder
http://www.yoyodyneti.com/ProductInfo.a ... 10.4776.83
http://www.bevelheaven.com/stuff-for-sa ... inders.htm
next to last one down the page just before the reservoir cups
here also
http://www.powersportsfx.com/sa/p/Bremb ... ushrod.htm
NOTE the push rod may not be the same length .but you can make a proper rod and have a new yoke and clip for it
also this one is 40 mm between the mount holes
and the price on the net seems to be reasonable
STILL LOOKING FOR REAR CALIPER
Postby DAVID THOMPSON » Mon May 27, 2013 4:29 pm
any one with a klr 650 2009 or newer and a 125 cc MZ
i do believe the rear caliper is a_match i also think the front will do the 125sx
on the hunt for spares
Postby DAVID THOMPSON » Sun Jun 02, 2013 11:15 pm
i finally ordered this item
as posted above in one of the posts
will see how it does when i get it here
the hose is in bad shape also
i took it all apart and cleaned it after almost 11 years was it a mess
definitely needed cleaned and new fluid
the whole unit comes off the bike in one piece
so i made a holder to use while bleeding it
so its not leaking on ME and the bike
worked out good
wanted to get it back together
as there is a local rally i go to in a couple weeks
its fun with out the long trip
only 24 miles 1 way
will post here about the brake repair and the rally
some really odd stuff shows up almost every year
Dave
