RT and SM/X interchangeable parts?
Postby kdesilva » Thu Oct 04, 2012 8:33 am
Hi there,
I've got the SM which is in fine working order, but I've got the chance to buy a non working RT, very cheaply, just for parts.
Does anyone know if there are any parts the RT has that can be used for the SM, that I can keep just in case something happens to the other bike?
kdesilva
Re: RT and SM/X interchangeable parts?
Postby DAVID THOMPSON » Thu Oct 04, 2012 9:28 am
body work is different frame may be different
rest is about the same
it all makes good trading stock for your spares bin
and if your in need of a part the supply department is very close
i think they sold a lot of these in your country
Postby stephendacosta » Fri Oct 12, 2012 7:32 am
Wheels are not interchangeable; I've tried. RT has shorter length in the speedo cable. Of course the radiator is one piece. the SM tank and seat will fit on an RT; haven't tried the other way.
Stephen DaCosta
stephendacosta
Postby stephendacosta » Fri Oct 12, 2012 8:19 am
From--- http://en.wikipedia.org/wiki/MZ_Motorra ... weiradwerk
MZ manufactured a line of 125 cc four-stroke motorcycles using an engine that was designed in-house. The MZ 125 produces 15 bhp (11 kW) and nearly 10 lb·ft (14 N·m) of torque. It is a liquid-cooled, dual-overhead-cam design with four valves, high-voltage electronic ignition and an 11,000 rpm ignition cut-off. This engine was used in four models, all of which share a common frame. The frame is a tube-steel backbone with the engine as a stressed bottom member. Differences in the suspension, fascia, gearing, and equipment make the four models relatively distinct, despite the shared platform. All four bikes feature a six-speed transmission and dual disc brakes.
Quoted for the "all of which share a common frame." Of course the FunX and SX models have no mounts for passenger footpegs.
Stephen DaCosta
stephendacosta
Postby stulemanski » Tue Apr 15, 2014 1:30 pm
Sorry for the thread resurrection - will a 125 SX bottom yoke fit a 125 RT?
stulemanski
Postby DAVID THOMPSON » Tue Apr 15, 2014 4:16 pm
there showing different part numbers in the parts book for sx and rt
only way to really tell is someone measure and compare a set
good machine shop may be able to salvage yours if its not too bad
Users browsing this forum: Bing [Bot] and 7 guests
