MZ 125 Tire Size
MZ 125 Tire Size
Postby kdesilva » Thu Sep 27, 2012 7:03 pm
Well I didn't get too much luck out of my other post, hopefully some specific questions will help!
I know a 140 can fit on the rear tire, but what can the front tire accomodate?
kdesilva
Re: MZ 125 Tire Size
Postby DAVID THOMPSON » Thu Sep 27, 2012 10:05 pm
rt or sm = 110/70/17 130/70/17
i am using KENDA K671 110/70/17f 130/70/17r
Postby pinhead1990 » Mon Oct 01, 2012 8:35 am
I'm runnin the bridgestone battlax bt45
pinhead1990
Postby kdesilva » Mon Oct 01, 2012 10:38 am
For the SM
110 and 130 are stock no?
I've heard of someone putting a 140 on the rear, wondered what could fit on the front.
I 've also been coveting a set of black rims - but I'm finding them impossible to find!!! Anyone know where I can get these from?
kdesilva
Postby sebamax2 » Sat May 11, 2013 8:55 pm
I know this is a bit old. But wanna update that 150 will fit the rear aswell . Fitted it today. It might even take a 160. It looks a little bit funny with the 110 at the front. But alot better than with the 130 ;)
sebamax2
Postby DAVID THOMPSON » Sat May 11, 2013 10:48 pm
found the kenda tires to be a good fit
watch getting them too wide may not fit the bead edge well and cause you to lose air
also after 11 years mine are losing air bad and need the inside of the rim cleaned and sealed
with something the alloy rims are going bad
my rear master cylinder is out and the caliper is in bad shape
going to put the saxon tour back on the road while i work on the mess
anyone know what brembo stuff fits the rear of an 2002 rt125
over here only some of the kymco scooters use the same fa197 pads
and they are rare also
Users browsing this forum: No registered users and 152 guests
