MZ RT125: How to check starter relay
Postby KAARVAAG » Fri Jun 17, 2011 9:03 am
Hello. I need some electrical parts for my Mz rt125 and to get the right part I needed to know if I had a round or a square starter relay. How can I found this out? I'm not much experienced with this at all,and have absolutely no clue what to look for. If somebody could help me out with a good explanation and/or pictures it would be very much appreciated! :)
- Ole Tohmmy Kaarvaag
KAARVAAG
Re: MZ RT125: How to check starter relay
Postby djsbriscoe » Sat Jun 18, 2011 6:13 am
It's the object with 2 large thick wires and 2 thinner wires attached to it. The larger wires are usually fixed to the starter solenoid/relay with ring terminals and 2 large nuts. It's probably made by Hitachi.
David.
Electronics tech by trade.
djsbriscoe
Postby DAVID THOMPSON » Sat Jun 18, 2011 8:58 pm
its under the seat near the tank and its round
do take the side cover off and unhook the battery before working on it
its a common part on Yamaha 4 wheelers
