125 RT START ENGINE
125 RT START ENGINE
Postby loykatoni » Thu Jan 21, 2010 6:47 pm
I HAVE A PROBLEM WITH MY BIKΕ,Ι FELLWITH MY BIKE.AFTER THE FALL I HAVE DEALT WITH THE FOLLOWING SITUATIONS:SOMETIMES THE STARTER DOESNT WORK ,WHEN IT DOES WORK ,IT SOUNDS LIKE IT STILL PROVIDES POWER TO THE ENGINE,DESPITE THE FACT THAT THE MOTOR IS RUNNING,THERE IS A MATTALIK NOISE NEAR THE GEAR BOX.THIS PROBLEMS SEEMS TO HAVE EMTIED THE BATTERY.COULD YOU POSSIBLY OFFER ME ANY SUGGESTIONS,FOR WHAT MIGHT DE HAPPENING??? :cry: :cry: :cry: :cry: :cry: :cry: :cry:
loykatoni
Re: 125 RT START ENGINE
Postby DAVID THOMPSON » Thu Jan 21, 2010 10:05 pm
under the seat just behind the bolt that holds the gas tank on is the starter relay..
some times they fail
in at least one case a rider reported to me that its contacts stuck on....making motor crank
also the switch on the handle bar may be sticking ..it may have been damaged but is not showing damage
Postby loykatoni » Fri Jan 22, 2010 7:44 am
thanks for the advice, i will check it..
loykatoni
Postby loykatoni » Mon May 03, 2010 1:21 pm
thanks that was the problem.. :-)
loykatoni
Postby loykatoni » Mon May 03, 2010 1:57 pm
What is the amaunt of preasure in the front/rear tire for RT 125
loykatoni
Postby stephendacosta » Sun May 16, 2010 6:07 am
That depends of the manufacturer of the tire. For optimum wear, reduce the recommended pressure on the tire sidewall by 10%. This bit of information is from a tire engineer for Goodyear. For maximim cornering footprint, you would use a lower pressure; I have not worked out what is best, yet. David Thompson might have a little more experience for that.--Steve
Stephen DaCosta
stephendacosta
Postby djsbriscoe » Sun May 16, 2010 9:14 am
From the user manual.
26 psi front, 33 psi rear at <=150KG weight.
maximum load 26 psi front and 38 psi rear.
David.
Electronics tech by trade.
djsbriscoe
